Translation_Bot
TC3XX ETH characteristics:
1. Supports 10/100/1000M Ethernet;
2. Supports MII/RMII/RGMII interfaces;
3. Supports full/half duplex working mode;
4. The maximum length of an Ethernet frame is 1522bytes;
Only TX DMA0 and RX DMA0 are used in 5.mCal.
The hardware structure diagram of ETH is shown in the following figure.
Key API interfaces in MCAL:
  1. eth_17_gethMac_init, used to enable and reset the ETH module and initialize the Mido interface;
  2. eth_17_gethMac_provideTxBuffer, used to create the specified buffer to be sent. The input parameters include Controller, BufferId, Buffer content, and length.
  3. eth_17_getHMac_setControllerMode, sets the mode of the Ethernet controller.
  4. eth_17_gethMac_getControllerMode to get the mode of the Ethernet controller.
  5. eth_17_gethMac_setPhysAddr, set the MAC address of the controller.
  6. eth_17_gethMac_getPhysAddr to obtain the MAC address of the controller.
  7. eth_17_gethMac_writeMii, set the contents of the PHY register.
  8. eth_17_getHmac_readMii, reads the contents of the PHY register.
  9. eth_17_getHMac_transmit, Ethernet data transmission.
  10. eth_17_getHMac_receive, Ethernet data reception.
  11. eth_17_gethMac_Tx, callback function for Ethernet data transmission.
MCA configuration:
The first step is to configure the clock reference, as shown in the following figure.
The second step is to configure the controller, including speed, operating mode, MCA address, buffer level, MDIO, etc., as shown in the following figure.
The third step is to configure the transmission and interface interfaces, enable RGMII read and write operations, and configure the form of data reception.
The fourth step is to configure the port hardware as the reset type. All input pins used for the ETH drive must be configured as port_pin_rgmii_driver, PORT_RGMII_INPUT, as shown in the following figure.
The fifth step is to enable the transmission and reception of DMA to be interrupted.
Step 6. Compile the configured generated.h and.c files into HighTec or TASKING.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E4%BE%8B%E7%A8%8B/Aurix-TC3xx-ETH-Demo/td-p/647552
Translation_Bot
Manually like and look forward to more sharing 👍 😁
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E4%BE%8B%E7%A8%8B/Aurix-TC3xx-ETH-Demo/m-p/649102
