Since I created an ON / OFF switch program using a proximity sensor (Simple Proximity Sensor Demo using Cy_CapSense_IsProximitySensorActive API on PSoC6 for MTB2.2), I made a 7th dice using it. When you bring your hand closer, the dice rotate, and when you move your hand away, it slowly stops. A description of the 7-eyes dice for MTB can be found in Let's make the dice of seven eyes on PSoC 6 with DMA & Beep for ModusToolBox2.2.
As a matter of fact, the proximity sensing program by MTB has created a project with a shared library up to this program, so all BSP settings are common. Therefore, please use the BSP of Simple Proximity Sensor Demo.
The environment used is as follows:
・ModusToolbox 2.2.1
・CY8CKIT-062-BLE
Kenshow
ispn:39619:1:0
l1:314:1:0
PSoc6
Hello @Kenshow ,
Thank you sharing this example project with the community. This is very useful 🙂
Dheeraj
