Clocks Forum Discussions
NXTY_Nagata
Level 4
Level 4
5 solutions authored First solution authored 100 sign-ins
Dear Supporters,
I simulated CY2305CSXC-1 and CY2305CSXC-1H using ibis model that can be downloaded from the following site, and got the same results.
I confirmed these ibis models are the same.
CY2305CSXC-1
https://www.infineon.com/cms/en/product/clocks-timing-solutions/buffers/cy2305csxc-1/#!simulation
CY2305CSXC-1H
https://www.infineon.com/cms/en/product/clocks-timing-solutions/buffers/cy2305csxc-1h/#!simulation
There is a difference in switching characteristics between CY2305CSXC-1 and CY2305CSXC-1H.
I would like to confirm this difference by simulating using the ibis model.
Please advise me on how to check.
Nagata
Hi @NXTY_Nagata ,
Currently there are no plans to update the IBIS model for CY2305CSXC-1H. So for now we will not be able to provide this model.
Pradipta.
PradiptaB_11
Hi @NXTY_Nagata ,
The IBIS model used for both the part numbers is same as you mentioned. The model was not revised to show the different switching characteristics for CY2305CSXC-1H. Currently you cannot simulate the new parameters for the device.
Pradipta.
NXTY_Nagata
Level 4
Level 4
Hi Pradipta-san,
Thank you for your answer.
Could you create&provide the ibis model that describes switching characteristic of CY2305CSXC-H1 ?
If it is possible, how long will it take?
Nagata.
Hi @NXTY_Nagata ,
Pradipta.
