generate programming file for CY29421FLXI-ND
anonymous-sj
First question asked Welcome!
I need help on how to generate programming file for CY29421FLXI-ND to give to the programming house.
we need to set the following options:
  1. Output=156.25MHZ
  2. OE=active low
  3. Set i2c address
  • What tool to use? Where to download?
  • What register to write
  • and what values?
PradiptaB_11
Hi @anonymous-sj ,
You can use the ClockWizard tool to generate the JEDEC file and the software will also help you to program the devices as well. You can also check out the programming kits for the same.
If you have any issues in generating the JEDEC file, do reach out to us as then we will generate it for you.
https://www.cypress.com/products/clockwizard
https://www.cypress.com/documentation/development-kitsboards/cy3641-programming-kit
Thanks and Regards,
Pradipta.
PradiptaB_11
Hi @anonymous-sj ,
Thanks and Regards,
Pradipta.
