Clocks
anonymous-sj
New Contributor
I just programmed CY29421FLXI-ND using the clockwizard. When look at each output (single ended) on the scope, i see both clk+ and clk- in sync. Basically clock complement is missing. was there any setting in clockwizard to set the second output as complement of the 1st output one that i missed?
PradiptaB_11
Hi @anonymous-sj ,
Can you share the ClockWizard project with us. We can check the settings used in the project for any discrepancies.
Pradipta.
