Hello.
I would like to use CY27410 with internal POR, and omit external reset.
Can I leave XRES pin to open?
Clock Buffers
Hi @Yas99,
You can't leave the XRES pin floating because it might be a reason for an accidental reset. So, to avoid that, kindly ensure that you have a pull-up resistor connected to that pin. Also, ensure that a decoupling capacitor (0.1 uF) is connected between the XRES pin and GND.
Ritwick
Hi @Yas99,
Ritwick
Hi Ritwick,
Thank you for your answer.
My question has been cleared.
