I'm exploring using the CY23FS04 to allow optional system synchronization with an external clock. I've had trouble finding any off-the-shelf pullable crystals. For a 100MHz system clock, I'd need a 16.667 MHz crystal. If I used the CY23FS08, I could also use a 12.500 or 25.000 MHz crystal. Does anyone know of an OTS source for pullable crystals at one of these frequencies?
-Greg
Clock Distribution
Hi Greg,
What do you need for the input and output frequencies for this device? this device is programmable actually so i can support for configuration and sampling for you.
For example, input=20MHz output=100MHz, crystal=25MHz etc.,
please contact me directly, my email is xht@cypress.com
XHT: applications engineer
Hi Greg,
