Hi @ericyu ,
There are no variants of a volatile memory version for CY22381. The is the only part there with flash memory inside to store the configuration information. Also currently the programming option is limited to factory only and field programming is currently not there. So generally the chips are programmed once and used by customer on their boards.
Hi @ericyu ,
Thank you very much!
And I notice that the non-volatility memory version of cy22381 , it is max programing times of cy22381 is 100 ,in cy22381 datasheet, but when I program this part cy22381fxit, it can be programmed only once, thus it can not be programed using a different pll output file, why? is it one time programing (OTP) part ? and other part number of non-volatility memory version of cy22381 ? thanks!
Hi @ericyu ,
The programming cycles also depend on the JEDEC file used for programming. If some of the bits in the JEDEC are programmed to 0 then the part will not be reprogrammable. So the JEDEC you are using might be using setting those bits if you are unable to reprogram the device.
Pradipta.
