09:26 AM
Sep 28, 2015
09:26 AM
I am using CY3679 Evaluation Kit to program the CY27410 chip. I am using the Clock Wizard 2.0 for programming the device. The issue I am facing is that the clock output power is shifting with the frequency (Please see the last slide of the attached ppt file). I am obtaining multiple frequencies from a single output pin.I would love to be able to change the frequency using the switches on the evaluation board, and have a constant output power. Most likely there is trick on the configuration setting of the software which I am not familiar with, so I would appreciate if I can receive help with this. Thank you in advance for your time and assistance.
Sincerely,
Muse Artan
Labels
