I am using CY3679 Evaluation Kit to program the CY27410 chip. I am using the Clock Wizard 2.0 for programming the device. The issue I am facing is that the clock output power is shifting with the frequency (Please see the last slide of the attached ppt file). I am obtaining multiple frequencies from a single output pin.I would love to be able to change the frequency using the switches on the evaluation board, and have a constant output power. Most likely there is trick on the configuration setting of the software which I am not familiar with, so I would appreciate if I can receive help with this. Thank you in advance for your time and assistance.
Sincerely,
Muse Artan
Programmable Clocks
Hi Muse Artan,
could you send across your project (.CPJ) file so that i can share the configuration
Where can I find details of the CY27410 registers?
Steve
