Clocks Forum Discussions
TeMa_2997106
Level 6
10 likes received 10 solutions authored 250 replies posted
Level 6
How should I calculate the power consumption? Is there a spreadsheet that can be calculated?
The data sheet have IDDs. However, the number of descriptions is small and the conditions are quite limited.
Tetsuo
TeMa_2997106
Level 6
Level 6
Pradipta-san,
Do Iddpm need to be considered? In my opinion, Itot is expressed by the following equation.
  Itot = Iddo + Iddpm
And in the data sheet, there is no mention of frequency other than CMOS. I want to use a differential output(LVDS). Is Iddo frequency dependent when using differential outputs?
Tetsuo
PradiptaB_11
Moderator 500 replies posted 250 solutions authored 250 replies posted
Hi @TeMa_2997106 ,
You can refer to our knowledge base article as below which also contains the formulas for calculation the power dissipation.
https://community.infineon.com/t5/Knowledge-Base-Articles/Calculation-of-Junction-Temperature-for-Cl....
Pradipta.
TeMa_2997106
Level 6
Level 6
Pradipta-san,
Is the "IDDO" in the CY27410 datasheet Idc or Iac? If it is equivalent to Itot, should I just look at IDDO?
Tetsuo
PradiptaB_11
Hi @TeMa_2997106 ,
IDDO will be the total current.
Pradipta.
TeMa_2997106
Level 6
Level 6
Pradipta-san,
  Itot = Iddo + Iddpm
Tetsuo
TeMa_2997106
Level 6
Level 6
Pradipta-san,
Please let me know the current status.
Tetsuo
