brcuc_2268776
"Fout/Fref appears to be a rational number, PLL configured for Integer-N mode for best jitter performance (FS0)." highlighted below -
Does anyone know if there is a way to disable this default function & still program the part in FRACTIONAL mode and NOT INTEGER mode?
PradiptaB_11
Hi Brooke,
The integer mode provides the best performance, so the clock wizard software is programmed to set the Integer mode PLL when PLL frequency differs lessthan 30-ppm between fractional and integer Mode.
There is no  way to disable this fucntion. You may need to change the reference input to achieve a fractional PLL setting.
Pradipta.
PradiptaB_11
Hi Brooke,
Pradipta.
