Clocks
TeMa_2997106
Level 6
250 replies posted 250 sign-ins 100 replies posted
Level 6
What is the output impedance of CY27410?
In the "Test and Measurement Circuits" of the data sheet, the test environment is described as 50 ohms for single end and 100 Ω for differential. Is it this value?
Tetsuo
PradiptaB_11
Moderator 500 replies posted 250 solutions authored 250 replies posted
Hi @TeMa_2997106 ,
Yes you are correct.
Pradipta.
TeMa_2997106
Level 6
Level 6
Pradipta-san,
Thank you for your comment. I understand.
Tetsuo
