01:02 AM
Mar 09, 2010
01:02 AM
Never came across a clock like this which can have a different personality after just changing the jedec file. Truly universal with the clock acting as a Clock Generator, Clock Buffer (ZDB/NZDB), Spread Spectrum Clock Generator for EMI Reduction and Application Specific Clock.
Moreover the InstaClock software acts as a Wizard to select the appropriate jedec file by giving you choices to select from in a Step by Step approach.
If there is no jedec file meeting the requirements, look at CY22801 that is totally configurable using CyberClocks R3.21.00 software.
Labels
Programmable Clocks
