Clocks Forum Discussions
user_4163646
We find Cypress Clock Generaotor.Input differential signal (161.13Mhz),Output single-end signal (25Mhz),
Please help provide Cypress products (Part number) for package SOP8/SOP16 ?
Because instead of  ICS840271I  ,please refer to the attached file.
Requirement:
  1.Input Frequency: 161.13MHz(differential)
  2.Ouput Frequency: 25 MHz (Single)
  3.Package : SOP8 / SOP16
Ex: Cypress CY27410 , but package SOP 48 Pin
PradiptaB_11
We checked the requirements and as of now we only have CY27410 to support it but it does not meet the package requirement you are looking for. CY27410 is a 4 PLL device hence the pin out and packaging is large or greater. We can only suggest you to use CY27410 from our side.
Pradipta.
PradiptaB_11
Pradipta.
