f5ezh
Hello
I bought some time ago an Instatclock CY36800 kit with 5 cy22800 circuits.
To be able to program more than these 5 components it is requested to register in the software
but the link is not successful.
Can you help me. I am already registered on the Cypress site. Thank you
f5ezh@free.fr
PradiptaB_11
The Insta Clock kit was obsoleted a long time back and the software was last supported on Windows XP and is no longer supported now.  I do not think you will be able to use the software. I will check internally within the team to see if there is a workaround and update the response if there is one.
Pradipta.
PradiptaB_11
Pradipta.
f5ezh
Hello
Thank you for your reply. Understood that the software is now obsolete but still having
a PC under Windows XP, I started programming the 5 circuits I had.
Unfortunately, after 4 programming, the software signals that it is necessary
to register to have unlimited operation, I would only have to
throw away the components which can be reprogrammed. cordially
