Create .JED file - Is CyClockWizard 1.0 the recommended tool?
GrCa_1363456
Level 6
Level 6
50 likes received Beta tester First comment on KBA
What is the recommended method to create a .JED file for CY25100 parts?
If CyClockWizard is the only option, is it compatible with Windows 10?
When attempting to run setup.exe after downloading from https://www.cypress.com/documentation/software-and-drivers/cyclockwizard-10?source=search&keywords=c..., a PopUpBox appears with the following text. Upon hitting the [OK] button, setup appears to exit.
CyClockWizard 1.0 requires that your computer is running at least Windows Vista 32-bit or Windows XP 32-bit SP2 or Windows Server 2003 32-bit SP1 or Windows Server 2008 32-bit or Windows 32-bit SP4 with IE 6.0.
Greg
P.S. There was a similar post stating CyClockWizard 1.0 is the tool to use. Reference: @ Re: CY25100; is possible to get a software tool to generate a file to program the part?
PradiptaB_11
Currently, there is no software tool to generate JEDEC file for CY25100 device on Windows 10 for general users.
The Cypress Support team however supports the customers by providing the JEDEC file to customers as per their requirements as we have the necessary tools to create the JEDEC file. You can let us know your requirements and we will provide you JEDEC file for the requirement accordingly.
Pradipta.
PradiptaB_11
Pradipta.
