idmo_4841796
First like received Welcome! First question asked
Hello
I redesign and old design with CY7B9950AXI.
CY7B9950AXI is discontinued, do you have any replacement or any other recommendation of  Multi-Phase PLL Clock Buffer
Nitin_Gupta
100 sign-ins 50 replies posted 25 solutions authored
Hi @idmo_4841796 ,
Unfortunately we don't have in drop replacement for this part. The closest replacement that i have found for this part is CY2308. You can see the datasheet for it using following link https://www.infineon.com/dgdl/Infineon-CY2308_3.3_V_Zero_Delay_Buffer-DataSheet-v21_00-EN.pdf?fileId... .
The adjustable phase feature is not there in  recommended part.
We also request you to use our product filter page to find the best suitable part for you.
You can access it at following link https://www.infineon.com/cms/en/product/clocks-timing-solutions/buffers/#!products
Here you can apply filters based on functionality you want.
Thanks and Regards,
Nitin
Nitin_Gupta
Hi @idmo_4841796 ,
Thanks and Regards,
Nitin
