Have CY294xxLXIxxxT factory-configured part number to replace CY2X014LXC100T?
If not, could you provide CY2X014LXC100T factory-configured content for make CY2942xFLXI sample?
Or provide CY2942x ClockWirzard project file for field-programming?
Programmable Clocks
Hi Mitchell,
The CY2X014LXC100T is obsoleted as you sated above. The next best alternative from Cypress is CY29421FLXIT. The JEDEC file for this device can be created using the Clock Wizard software. We can create a JEDEC file for you as per your requirements. I am providing the datasheet link below. Please use table 1 as a reference and let us know your requirements for the design and we will create the file for you.
https://www.cypress.com/file/280111/download
Pradipta.
Hi Mitchell,
Pradipta.
Dear Pradipta.
Have possible to provide CY2X014LXC100T configured data for reference.
I can make JEDEC file by myself.
We just follow LSI3616 customer reference board(CRB) design to get recommend parts is CY2X014LXC100T.
So we just need to do same as CY2X014LXC100T functional configuration in CY29421FLXIT.
Mitchell
