Kindly help us to know the clock programmer kit for CY27410FLTXI.and provide EOL of the part
Duraiselvi
Clock Distribution
Currently there is no EOL planned for this part as we plan to promote and support this part in the long run. You can find all the information for the evaluation kit of the device in the below link. If you are specifically looking for a programming kit for the device then you will need to contact your nearest Sales/FAE/ marketing representative Infineon and provide details on your use case to the Business Unit. Generally we ship programmed samples to the customer but we can also provide a programming board for the device if you want to program the devices at your end.
Pradipta.
Pradipta.
Hi Pradipta,
Thank you.
Please confirm CY3675 clock maker clock programming kit is suitable for CY27410 programming. also provide the socket adapter part for 48-QFN package. or else kindly provide programming board details.
Regrads,
Duraiselvi C
The CY27410 has a separate programming kit. You do not need to purchase CY3675 Clockmaker kit to program this particular device. I will provide you the programming board details separately via mail.
Pradipta
