Clocks
dalton
New Contributor
Hi All,
I am using the CY26049-20 as a synchronized clock filtering circuit with  with fall back
So I hope to apply a 25MHz ICLK   and obtain a  100 MHz phase locked output, and using a 25MHz XTAL input
Obviously I am having some difficulty getting it to function properly
I was wondering if there are any application,  layout guide,  notes or any data at beyond the basic datasheet for this part. I am using the  the -20 par but the only datasheet I can find is the -36 version. so even getting  the -20  or generic data sheet would be helpful.     Too bad there is no Eval board for this part 🙂
PradiptaB_11
Hi @dalton ,
The CY26049-20 is not a valid MPN (We do not know from where you got a -20 part). The -36 is a valid MPN and hence there is datasheet for this code. Also coming back to CY26049 this device has been obsoleted for many years now and hence finding any documentation for this or support for this part  will be very difficult.
Pradipta.
PradiptaB_11
Hi @dalton ,
Pradipta.
dalton
New Contributor
Yes I saw 26049 was obsoleted in 2018 or 2019 but it suited my needs almost exactly.
Hi Pradip,
Thanks for your swift reply.  Yes I saw 26049 was obsoleted in 2018 or 2019 but it suited my needs almost exactly.
I would appreciate any additional info you can provide as the data sheet alone for the -36 party is a little sparse.
Was there ever an eval board for this family?  It seems to me that there would have been an app note with this part family at one time too.
PradiptaB_11
Hi @dalton ,
I did not find any app note that would help your cause in our system. There may be a evaluation board but currently i cannot confirm this. Since the device the was obsoleted the hardware related to it was shifted to storage. Since currently we are operating from home i cannot confirm if the board is there and in working condition.
Pradipta.
