NaMo_1534561
Distributor - Macnica (Japan)
100 replies posted 100 sign-ins 50 replies posted
I have a question about the Cypress clock buffer (CY2308ZXI-1HT).
The Switching Characteristics parameter t5 specifies the output skew between each port of the output terminals CLKA1 to 4 and CLKB1 to 4.
t5 is,
- using internal PLL (S2 = 1, S1 = 1)
- does not use the internal PLL (S2 = 1, S1 = 0) (= Mode that outputs the REF clock signal)
In either case, is the output skew between each port specified by t5?
MPN: CY2308ZXI-1HT
Data sheet "Document Number: 38-07146 Rev. * T"
https://www.cypress.com/file/38856/download
Naoaki Morimoto
PradiptaB_11
Hi Morimoto-san,
The t5 parameter which the output to output skew is valid for both modes (when PLL is used and when only REF is used and PLL is bypassed). In either case the output skew between each port specified by t5.
Pradipta
PradiptaB_11
Hi Morimoto-san,
Pradipta
NaMo_1534561
Hi Pradipta-san,
Thank you for giving answer. This query has been resolved.
Naoaki Morimoto
