NiAl_4839656
Hello all,
What is the CY2302 Loop filter Bandwidth?
Can I use it for jitter attenuation application?
Nir
PradiptaB_11
Hi
The loop bandwidth is roughly about 100 KHz. As it is a public forum cannot share the exact number but you can use the mentioned value for all practical purposes.
As far as using it for Jitter attenuation go you will need to check the jitter which is already present in inside the bandwidth as that will be amplified. So if it is within the range for your application they you can use it for cleaning jitter.
Pradipta.
PradiptaB_11
Hi
Pradipta.
Thanks Pradipta.
Nir
