The Cypress CY22801 is listed on the Infineon website as an "active and preferred" device, and I would like to design a product using it. The field programming tool listed in the datasheet however is obsolete and no longer available.
What hardware is currently available to perform field programming of this device in prototype quantities?
Programmable Clock
- CY22801
Hi @diapulserx ,
For programming the CY22801 there are currently two options available.
1) You can provide us your required configuration and directly get the programmed parts for your end application. (We will also support samples for testing purposes)
2) If you want to program the blank samples at your end then we can provide you with the CY3675KIt and a CY22801 specific adapter card which will be the hardware required for the programming. The software is readily available on our website.
Pradipta.
Hi @diapulserx ,
Pradipta.
