CSD
MAO
Distributor - Macnica (Japan)
5 solutions authored 50 replies posted 100 sign-ins
What is the min / max value of Vref of CSDv2?
NaMo_1534561
100 replies posted 100 sign-ins 50 replies posted
For 4th generation CSD components, Vref is variable depending on Vdda. See the Vref section of the component data sheet.
The Vref spec of the IC data sheet is wider than the component data sheet from min 0.6V to max Vdda-0.6V because it includes the conditions when using Vref as a reference for the comparator in addition to using it for the CapSense component.
Naoaki Morimoto
NaMo_1534561
Naoaki Morimoto
