Hello community,
I am looking for an alternative component to the CY25823. The component must not be pin compatible, but function compatible.
Does anybody know an alternative or the possibility to reproduce this component.
Regards SAKRDI
Hi @SAKRDI ,
We apologize slow response for your request above at first.
Based on the datasheet of CY25823, We recommend CY25200KFZXC the datasheet for the same you can find it at following link .
We also request you to use our product filter page to find the best suitable part for you.
You can access it at following link https://www.infineon.com/cms/en/product/clocks-timing-solutions/clock-generators/#!products
Here you can apply filters based on functionality you want.
Thanks and Regards,
Nitin
Hi @SAKRDI ,
Thanks and Regards,
Nitin
