- Email to a Friend
dear support team,
could you help to clarify what is the modulation approach of IR 4302M like AD or BD mode? and are all infineon class d amp use the same moulation mode? thanks!
BR,
Particles
- Email to a Friend
Hello @Particles,
If you are referring to two-level and three-level PWM by AD and BD mode, then IR4302M uses two level PWM technique or AD modulation mode.
Infineon Class D portfolio also has amplifiers with multilevel switching block. You may explore them using below links.
Hope this helps.
Meghana R
- Email to a Friend
Hello @Particles,
Hope this helps.
Meghana R
- Email to a Friend
Thanks Meghana! That is quite clear!
BR
Particles
