Does anyone have GUI software to change PMP5 registers?
BR
Toshinari Ikeuchi/TED
Hello Toshinari,
Please find attached the Software GUI.
In order to do this you will have to write the registers manually in the register browser.
here is an example of this settings for PMP5 on register address 29 (decimal)
Thank you for your reply. I have one more question. A customer want read/write to address 21/22/23 through I2C. Are there any solution for resolving this?
BR
Hello @ToIk_1341346 ,
If the registers are in the datasheet, then it is possible to read/write them. If not, it is not recommended.
The current version of the GUI only supports address 0x20 on I2C. To read other addresses, you have to have your own MCU and write the corresponding driver code to read and write I2C. Since this GUI and board is for evaluation only, you can configure the board to 0x20 address and use the UI.
Pranava
