Question about MA2304
Miyata
Level 4
Level 4
Distributor - TED (Japan)
First comment on KBA 25 replies posted 10 solutions authored
Hi, We delivered MA2304 evaluation board to our customer and customer get back to us with several question regarding MA2304.  Pls respond back to us with your answer.  Appreciate for your support.
Q1) There are four power mode in MA12070P but regarding from datasheet of MA2304, there are only two power mode. As below.  Is my understanding correct?
Q2) If the above recognition is OK, MA2304's LCP mode is MA12070P's D Mode, and HAP mode is MA12070P's
It seems to be equivalent to B mode, is my understanding correct?
Q3) If the above understanding is OK, is it OK to understand that the PWM modulation method of MA2304 is only 5-level (there is no 3-level)?
Q4) If the above understanding is OK, why did you abolish 3-level?
Q5) "PM0/PM1/PM2/PM3" on the Configuration screen (see below) of the GUI tool (MERUS™ audio amplifier configurator)
   There is a display, but in what situations do these lights up?
Shiva_C
25 solutions authored 50 replies posted 100 sign-ins
Please refer to the below comments.
Q1) There are four power mode in MA12070P but regarding from datasheet of MA2304, there are only two power mode.  Is my understanding correct?
Yes, correct-
Yes, similar but not exactly the same. For this purpose please observe table 7 in MA2304 datasheet:
Yes, typically 5-level modulation provides better efficiency performance.
This is to simplify applications. MA2304 still support 3-level modulation with common mode free content. However, the common mode content of 5-level is already significantly lower than traditional 2 and 3 level modulation. Please contact us if 3 level modulation is desired.
https://community.infineon.com/t5/Class-D-Audio-Amplifier-IC/Question-about-MA2304/td-p/624822
This is only for debugging purposes and can be ignored. These “PMx” are different power modes (not power mode profiles) that are optimized depending on the output level.
Thanks!
Shiva_C
Yes, correct-
Thanks!
Miyata
Level 4
Level 4
Thank you for your response.  Already forward your input to our customer.
If customer have any additional questions, pls give us your support again.
