Hi Sirs,
I have a MA2304DNS EVAL Board, I can use this EVK to play music to speaker. But it seems not working when I adjust EQ,
here is the procedure:
1. connect power and speaker to EVK
2. Input audio <--I can hear the music correctly.
3. Run Merus 1.0.0-819
4. go to DSP page and setup low pass filter with fc at 100Hz (see attachment)
5. "APPLY".
5.1. I notice warning symbol is gone, after press "APPLY".
5.2. Music output from EVK disappear
6. reboot EVK
7. audio same as before, no any change (by ear)
I also tried different input signal such as 1kHz sine wave with 100Hz cutoff freq, but 1kHz audio still loud and clear after reboot.
My questions are:
1. Please help clarify above configuration procedure, I don't know where is the mistake.
2. Is reboot EVK necessary? I expect chip should reflect EQ result immediately after uploading, no need to reboot.
3. Can I read out filter parameter to Merus and display to DSP page ?
J66
Hi @amusz , Thank you for the reply.
Please find attached GUI.zip.
The issue I encountered is different from the one you provided. My PC can connect with EVM, I can control EVK volume by initial control panel(the one above the "refresh" button), but DSP parameter seems not working.
After I "APPLY", EVK stop output music, I have to reboot the EVK. and the DSP parameter I set early seems not exist in the EVK. (test audio is 1kHz sine wave)
Please provide your suggestion.
Hi @Julian66,
I loaded the configuration folder from the GUI.zip file you provided and ran some tests. Below is a frequency response plot of the default configuration (flat) and also for the configuration you shared (-20dB cut + 2.25dB volume setting):
No. In general, if the EVK ENABLE switch is turned OFF and then ON, it will reset the part into its default state. That's the state the part is in while you adjust the volume control. This is why the DSP parameters go back to default when rebooting the EVK, as you mentioned.
If the Connected indicator (initial page), press the REFRESH button and the indicator should turn green if the MA2304 is detected:
The MA2304 remains in its default state after loading the initial screen or pressing the REFRESH button. The MA2304 plays audio without any register configuration.
Yes, that is expected:
Before loading DSP code into device:
After clicking the APPLY button:
When clicking APPLY the MA2304 is muted for a few seconds while the DSP code is programmed through I2C and then automatically unmuted.
No. The GUI does not sync the DSP page with the amplifier registers.
The steps look OK, except that there is no need to reboot the EVK.
Things to check:
- Check in the back of the PCB if there is a sticker with a serial number. Above the serial number, there should be the EVK name: EVAL_AUDIO_MA2304DNS. If it is not DNS (e.g. PNS), then that could be the problem.
- Make sure jumpers are set to default per the user manual.
Otherwise, it might be possible that the EVK you have is defective. We can ship an additional board if needed.
m60dbfs
Hi @Julian66 ,
We'll try to reproduce with your shared file and come back within 24hs/48hs max, to see if it's a hardware or software related issue.
Hi @Julian66 ,
Please give us one more day, one of our support engineers is taking a look.
Hi @Julian66 ,
Thanks for posting the EVK picture.
To double check:
- What is the PVDD supply voltage set to?
- What is the speaker load?
- What is the state of the STATUS page before and after pressing the APPLY button? Before clicking APPLY, click the CLEAR button in the STATUS page to clear any flags as shown below.
m60dbfs
1. 19VDC
2. 4 ohm
3. All Green
