Ivan_Lee
Level 5
Level 5
Distributor - Zenitron(GC)
100 replies posted 5 likes given 100 sign-ins
currently we have a MA12070P - board that can work with 44.1kHz@16bits sample rate,
but can't work with 48khz@24bits. ( no voice output)
So we have some questions :
1. Does MA12070  support 48khz - 24bits - audio sample rate ?
2. Do i need to set i2c registers for different sample rate?
3. Can you give us i2c setting for 48khz - 24bits ?
4. Is there have any hw setting  for diffetent sample rate?
Pranava_YN
This CLK should come from Audio Source as shown in following figure
The value of this clock can be anything mentioned in the Table 8-11.
Pranava
Pranava_YN
Hi Ivan,
1. MA12070P does support 48khz 24bits.
2. Yes, you would need to set I2C register not for different sample rate but for bit width.
3. Please change the value of 0x35 and 0x36 registers to match the audio imput format on your side.
4. There is no hardware setting for different sample rate. please refer to Table 8-11 in the datasheet and provide appropriate CLK frequency.
Pranava
Ivan_Lee
Level 5
Level 5
Hi, Pranava,
48khz and 44.1khz has different CLK frequency, how to chagne CLK frequency ?
Pranava_YN
Pranava
