mattw2727
Clarification question:
On the Datasheet for the MA12040P Amp IC, pins 49 and 64 are designated as do not connect, as they are internally connected to 5V -- however, on the MA12040P Amp Eval board (and documented on the eval board schematic) these pins are externally connected to 5V.
We've got jumpers on our board so we can connect to 5V or not --
Can you provide guidance here?  Why is the eval board connecting these pins to external 5V, despite the Datasheet guidance?
amusz
25 replies posted 25 sign-ins 10 solutions authored
Hello!
Pins 49 and 64 should not be connected. We have already corrected this in the new evaluation boards and reference designs.
amusz
Hello!
Happy
25 sign-ins 10 replies posted 10 sign-ins
HI~~,I think 55, 49, and 64 pins can flexibly layout the DVDD connection layout on the PCB, I don't know if it's right!
amusz
Hello!
MA12040P is not recommended for new designs. Instead we strongly recommend MA2304DNS or MA2304PNS
mattw2727
Thanks for the quick confirmation on the DNC - appreciate it!
Best regards, MW
Happy
我认为 55、49 和 64 引脚可以在 PCB 上灵活布局 DVDD 连接布局,不知道对不对!
