Hi.
What method can I use to start the EVAL_AUDIO_MA12070P with different settings than default without using the GUI on a PC?
- MA12070P
The EVAL AUDIO MA12070P starts up in default mode when power is applied, or power is cycled.
Changing/loading settings should be done via a host MCU system via the I2C communication lines.
Please see MA12070 datasheet p23. for I2C communication setup MA12070P Datasheet
For inspiration, please see this application MA12070P_Arduino_MKR_amp.
