Class D Audio Amplifier IC Forum Discussions
PhilGood_82
5 sign-ins First reply posted First like given
Hello everybody
Using IRS2452AM for class D amplifier solution, we face a problem when output current on the load increases : output signal is disrupted on the negative side of the signal (see attached file) ; after checking other points, we see that PWM output signal is also disrupted.
All power supply seem clear.
Has anyone ever encountered this type of problem ?
Thank you
SC
10 likes received 25 replies posted 10 solutions authored
Can you please share us the SCH and Layout file for analysis.
BR,
SC.
bluespark
First reply posted Welcome!
Here are 2 additional pictures of the problem we encounter with PhilGood_82: in yellow is the output of the low pass filter behind the half-bridge, and in pink is the PWM output from the IRS2452AM (pin 15 HO1). You can see the strange behaviour of the HO1 pin, what can be the root cause?
SC
BR,
SC.
