XENSIV PAS CO2 on ESP32
Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
rmjimeno
First question asked Welcome!
Hi, I would like to ask how can I use the XENSIV PAS CO2 sensor with my ESP32 board. I have managed to make the sensor work using an Arduino board using the sample code and the library but I would like to use the sensor with my  ESP32-based board and I have not found any libraries for ESP32.
Any help would be appreciated. Thank you!
George_T
50 likes received First question asked 250 replies posted
Hi @rmjimeno,
Please refer to the updated library for PAS CO2 sensor in the following link
https://github.com/Infineon/arduino-pas-co2-sensor/releases/tag/v3.0.2
Please let me know whether the issue is resolved.
Thanks and regards,
George
George_T
Hi @rmjimeno,
Sorry for the delay in response. The sensor can be interfaced using I2C.
Please refer to the Programming guide for XENSIVTM PAS CO2 as a starting point.
Thanks and regards,
George
Ilkka
First like given First reply posted Welcome!
Infineon PAS CO2 sensor needs 12 V power supply for the IR emitter according the documentation. Esp32 has no 12V.
Is there any simply solution for that?
BR, Ilkka
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Hi Moto, thank you very much for the reply and information.
BR, Ilkka
dmpolukhin
I had the same issue with ESP32 and PlatformIO with the latest library "infineon/XENSIV PAS CO2 @ ^3.0.2". In my case weak stub function xensiv_pasco2_plat_i2c_transfer from `src/xensiv_pasco2.c` was called instead of platform implementation from `src/pas-co2-pal-ino.cpp`. When I removed stubs everything start working fine.
George_T
Hi @rmjimeno,
Thanks and regards,
George
George_T
Hi @rmjimeno,
I would like to add one more point to check that the latest version of the ESP32 driver is installed in the Arduino IDE.
Thanks and regards,
George
