- Email to a Friend
Is there the reliability specifications of PAS CO2?
Especially, the customer wants to know " Vibration Test" and "Mechanical shock".
H.N
CO2 Sensor
- Email to a Friend
Hi @h_nakamura ,
The test conditions are as stated below :
For mechanical shock :
1500g / 0.5msec /
direction +/-x,y,z
(5 shocks in each direction)
For Vibration :
20 to 2000Hz with a peak acceleration of 20g in X, Y and Z for 4 minutes each
Hope this helps !
Deepa
- Email to a Friend
Hi @h_nakamura ,
The system design guidelines have been stated according to the tests performed as listed in https://www.infineon.com/dgdl/Infineon-PAS_CO2_General_Design-In_Guideline.docx.-ApplicationNotes-v0... .In case of vibration, the only critical frequency would be low frequencies so if these can be isolated, the sensor will be very robust and in addition, it is IEC 60068-2-6 qualified. As for mechanical shock, the sensor is IEC 60068-2-27 qualified.
Deepa
- Email to a Friend
Hi Deepa,
Is it possible to provide the test condition of the vibration and shock?
N.N
- Email to a Friend
Hi @h_nakamura ,
Few of the tests are listed in the application note https://www.infineon.com/dgdl/Infineon-PAS_CO2_General_Design-In_Guideline.docx.-ApplicationNotes-v0... . Please go through it and let us know if you have any more queries on the same.
Deepa
- Email to a Friend
Is it possible to know the test condition of IEC 60068-2-6 and IEC 60068-2-27 because I heard that the vibration is IEC 60068-2-6 qualified and the mechanical shock is IEC 60068-2-27 qualified.
N.N
- Email to a Friend
Hi @h_nakamura ,
1500g / 0.5msec /
direction +/-x,y,z
For Vibration :
Hope this helps !
Deepa
- Email to a Friend
Hi Deepa, sorry for my late response.
Thanks for your help. I understood it.
N.N
