Dear Community,
I am wondering if it's possible to significantly improve the response time of the CO2 sensor by for example removing the membrane covering the sensor casing (white dot in image below).
What is the purpose of this membrane? Protect from dirt and moisture? If the sensor would be used in an otherwise "safe", i.e. dry and clean environment, would one need the membrane? I am aware that the warranty would be void when using the sensor in this way, but we need a much faster response than what the sensor can do with the current setup and this sensors speed is certainly not limited by the measurement principle.
I hope someone can help!
Johannes
CO2 Sensor
Hi @r0oland,
Yes, you are right. The membrane is for protection from dirt.
Regarding the response time, thanks for the feedback and the same is communicated to the design team.
We are always on the path improving the sensor performance.
Thanks and regards,
George
Hi George, thanks for the reply. But my questions remains unanswered:
Does removing the membrane increase the response time? Maybe you could forward the question to the design team?
