Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
MaKo_4831421
Distributor - Macnica (Japan)
50 questions asked 5 likes given 100 sign-ins
The CO2 Sensor board can not connect to the PC software.
DaTra_4942216
Level 4
Level 4
10 replies posted 10 sign-ins 5 solutions authored
There are two versions of XENSIV PAS CO2 Sensor2Go GUI till now (2021 Sep 29th)
For version 1.1.2 you need to check in the box where the sensor shows and then press connect. (see picture version 1-1-2 below)
For version 2.8.0 the sensor is connected automatically after you connect the USB port. (see picture version 2-8-0 below)
So you may want to update your Toolbox and CO2 Sensor2Go GUI to newer version.
Note: You can choose which version to start from the toolbox start up screen (see picture version-change below)
DaTra_4942216
Level 4
Level 4
