CO₂ sensor Forum Discussions
Frank_vec
Level 4
Level 4
100 sign-ins 25 replies posted 10 questions asked
1、您好 ,现在计划 使用 EVAL_PASCO2_MINIBOARD ,Infineon官网有 原理图SCH等
2、但是没有发现 EVAL_PASCO2_MINIBOARD PCB layout的Ad文件 和 EVAL_PASCO2_SENSOR2GO的 PCB layout文件和软件程序;我想layout一个PCB,EVAL_PASCO2_MINIBOARD  直接对插就可以了,现在不知道MINI BOARD 的插针具体数据
3、UM_XENSIV_PAS_CO2_miniboard-UserManual-v01_01-EN  这个是PSOC6+EVAL_PASCO2_MINIBOARD  ,请问程序在哪儿下载呀 ?
TEL:17317187679
WangYaran
50 replies posted 250 sign-ins 25 solutions authored
Hi Frank,
See you again~
About your required programming details can be found in the following Github page:
https://github.com/Infineon/sensor-xensiv-pasco2
About the PCB , CO2 sensor board schematic is available in the following link:
https://www.infineon.com/cms/en/product/gated-document/reference-design-sensor2go-evaluation-kit-554...
other information  may not be available except below:
BR
Yaran
WangYaran
Hi Frank,
See you again~
BR
Yaran
