Hi everyone
For used the I2C communication, the 2 pin (RX) and 9 pin (PWM) set to OPEN is should be no problem?
yang
CO2 Sensor
Hi, Yang
For I2C communication, there is no problem with OPEN for 2 pin (RX) and 9 pin (PWM).
Figure 4 in the User Manual P4 of the Infineon PAS CO2 mini-board in the link below and the table at the bottom show the configuration used in I2C communication. In this configuration, 2 pin (RX) and 9 pin (PWM) are set to open pen.
https://www.infineon.com/dgdl/Infineon-UM_XENSIV_PAS_CO2_miniboard-UserManual-v01_01-EN.pdf?fileId=5...
u-s
Hi, Yang
u-s
