CO₂ sensor Forum Discussions
MaKo_4831421
Level 4
Level 4
50 sign-ins First like given 25 sign-ins
How frequent should we input pressure compensation?
We have a pressure sensor in their system, so customer can reflect the value from their pressure sensor into CO2 sensor. Thus, we want to know how frequent should (can) we input the pressure value to CO2 sensor. Is it OK to input the CO2 compensation value every cycle?
DaTra_4942216
Level 4
Level 4
10 replies posted 10 sign-ins 5 solutions authored
For indoor application we have the following assumptions:
a. Device is a placed inside a building
b. The height is not changing every hour
c. The ambient pressure is not changing for every 6 hours
If the assumption is true, then it is sufficient to update the pressure once every 6 hours. However, if someone is living in a multistoried building, then it is recommended to change the pressure when someone move from one floor to another along with the device. This can be identified by recording the pressure sensor value within the system.
DaTra_4942216
Level 4
Level 4
