CO₂ sensor Forum Discussions
MaKo_4831421
Level 4
First like given 25 sign-ins 10 replies posted
Level 4
What will happen if humidity is over 85% (the device will break? or only the accuracy will decrease? )
AditiB_81
Moderator 250 replies posted 250 sign-ins 100 solutions authored
The sensor's operating range has been limited to 85% RH to cover most of the common use cases. Beyond 85%, the sensor performance will be impacted but the device will not be dead at a high relative humidity level unless the device is not submerged into water.
Aditi
DaTra_4942216
10 replies posted 10 sign-ins 5 solutions authored
The sensor will only be damaged if condensation happen. Otherwise, higher humidity level will only impact the accuracy.
AditiB_81
Aditi
