About humidity of CO2 sensor
Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
MaKo_4831421
Level 5
Level 5
Distributor - Macnica (Japan)
50 questions asked 5 likes given 100 sign-ins
What will happen if humidity is over 85% (the device will break? or only the accuracy will decrease? )
Aditi_B
500 replies posted 5 questions asked 250 replies posted
The sensor's operating range has been limited to 85% RH to cover most of the common use cases. Beyond 85%, the sensor performance will be impacted but the device will not be dead at a high relative humidity level unless the device is not submerged into water.
Aditi
DaTra_4942216
10 replies posted 10 sign-ins 5 solutions authored
The sensor will only be damaged if condensation happen. Otherwise, higher humidity level will only impact the accuracy.
Aditi_B
Aditi
