About calibration of CO2 sensor when operating
Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
MaKo_4831421
Distributor - Macnica (Japan)
50 questions asked 5 likes given 100 sign-ins
Does the user need to calibrate during operation?
DaTra_4942216
Level 4
Level 4
10 replies posted 10 sign-ins 5 solutions authored
About: Automatic Baseline Offset Compensation
- In order to correct slow drifts caused by aging during operation, the device supports Automatic Baseline Offset Compensation. Every week of operation, the device computes an offset to correct the base line of the device.
- So if you enable Automatic compensation, the latest valid computed offset is automatically applied to the measured CO2 concentration value.
Please note that In single shot mode, automatic compensation is disabled by default.
For more information about calibration please refer to the below AN:
https://www.infineon.com/dgdl/Infineon-AN_FCS_ABOC_XENSIV_PASCO2_2-ApplicationNotes-v01_00-EN.pdf?fi...
DaTra_4942216
Level 4
Level 4
