Hello everyone
I'm new to dealing with psoc, and I'm trying to get the CY8CKIT-022 Sensig fluid level protector working.
I tried using Tera Term for this operation (according to the user guide), and I used both the hex files and burned them directly using the psoc programmer, and the psoc creator files, all from here: https://www.infineon .com/cms/en /product/evaluation-boards/cy8ckit-022/
I have a few questions:
1. The 12-RX sensor was working fine, and I was able to see an update of data while filling the tank with liquid. This is, for example, from the term tare while filling the container:
container:
But when I did this with the 2-RX sensor, I didn't see any update in the tera term, and it stayed at the same output when I filled the container, even when I filled it to the top. Anyone have an idea why?
2. I tried using the term commsnds of tera but I'm not sure what their output should be. If someone can explain this in detail I would appreciate it:
This is the output of the csv command
Can someone explain what each column (detailed at the beginning) means?
And when I use enter command, this is what the output should be:
and this is the actual output (for example):
What does each number in this set mean?
If anyone has any advice for good operation of the 2RX sensor, or even a document in addition to the usr manual of infineon, I would greatly appreciate it.
In addition, if anyone has an idea how to produce the output with an analog signal and not through a tera term, that would help me a lot
Many thanks in advance
CapSense
ispn:39601:1:0
l1:314:1:0
Hi @Isela31 ,
The discussions shall be held in the following thread: https://community.infineon.com/t5/CAPSENSE-MagSense/capsense-via-tera-term/td-p/437816
Nikhil
Hi @Isela31 ,
Nikhil
