CAPSENSE™ & MagSense Forum Discussions
MaMi_1205306
Level 7
Level 7
500 replies posted 50 solutions authored 25 likes received
Dear Sirs and Madams,
We are considering using the MBR3 series due to the difficulty of obtaining PSoC4.
I understand that sensor information is used by reading the "BUTTON_STAT" register, but when should the "LATCHED_BUTTON_STAT" register be used?
Perhaps I thought the "LATCHED_BUTTON_STAT" register was only used for GPIO toggle purposes.
Is there any difference in using it?
ncbs
50 likes received 250 sign-ins 250 replies posted
Hi @MaMi_1205306,
If you require the current status of the button and wish to take some actions based on that, you would read BUTTON_STAT.
In case you require the history of touch on a button (i.e., if a button was ever pressed or not since the last time LATCHED_BUTTON_STAT was cleared), then LATCHED_BUTTON_STAT needs to be read.
In short, if the current status of the buttons is required, then use BUTTON_STAT.
Nikhil
ncbs
Hi @MaMi_1205306,
BUTTON_STAT gives the current status of the buttons. And LATCHED_BUTTON_STAT register copies of set bits in BUTTON_STAT since the last time LATCHED_BUTTON_STAT was cleared. The usage of this register would be application specific. For example, if it is required to be known if a button was pressed or not, LATCHED_BUTTON_STAT would hold that data (provided it wasn't cleared).
Nikhil
MaMi_1205306
Level 7
Level 7
Nikhil-san,
Thank you for your support.
When we check the state of the sensor in general usage, we only need to refer to the "BUTTON_STAT"  register, right?
Or is it better to check and clear the "LATCHED_BUTTON_STAT" register?
ncbs
Hi @MaMi_1205306,
Nikhil
MaMi_1205306
Level 7
Level 7
Nikhil-san,
I understood how to use them.
Thank you,
