CAPSENSE™ & MagSense Forum Discussions
DuSt_4713121
The user manual does not have any info on how to connect  the device; what do I need to connect the I2C lines to the computer that EZ-Click will recognize?
Dusan
Hari
Hi DuSt_4713121
MiniProg4 does not recognize the Ez-Click software. You can use the MiniProg3 for configuration.
EZclick support with Miniprog4
Hari
Hari
Hi dust_4713121
The MBR3 kits have an onboard kitprog that does the conversion from I2C to USB. In case you are using a custom board, you can use any I2C to USB converters or a Miniprog for connection.
There is an option to "Select Target Device" in EZ-Click. Make sure that the MBR device is connected to the computer and it will show up in the available ports as shown in the figure.
Do let us know if the connection is successful.
Hari
I was looking more on a hardware solution. I have a cy8cmbr3110 on a custom board and access to the I2C pins. Can I use an CY8CKIT-005 MiniProg4 to connect?
Dusan
Hari
Hi DuSt_4713121
Hari
