Langir
Hi dear
We try use the EZ-Click V2.0 for CY8CMBR3102-SX1L, after click Apply current config the file cannot apply in it. please kindly check the attached file.
Panda
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @Langir,
You are attempting to apply configuration to CY8CMBR3116-LQXI but the project has been created for CY8CMBR3102-SX1I. Since there is a mismatch in the devices, the Apply current configuration step fails.
I guess you are using CY3280-MBR3 CapSense® MBR3 Evaluation Kit. If so, then change the project to CY8CMBR3116-LQXI. You should positively be able to proceed ahead without any errors.
Nikhil
ncbs
Hi @Langir,
Nikhil
Langir
Hi Nikhil
How are you? That's correct the Kit for  CY3280-MBR3. At presest the MCU we use CY8CMBR3102-SX1I. can you let's know how do test in the Kit?
Rgds
Panda
ncbs
Hi Panda [ @Langir ],
Greetings!
CY8CMBR3116-LQXI is the device present on CY3280-MBR3 CapSense® MBR3 Evaluation Kit. The same can be found in the kit's schematic file.
To create a project for CY3280-MBR3 CapSense® MBR3 Evaluation Kit, go to File -> New Project. In the New Project window that pops up, select CY8CMBR3116-LQXI under Target Device.
Let me know if this helps.
Nikhil
Langir
That’s clear. Thanks again
