PSoC Creator component datasheet (PSoC4 CapSense) have been updated from v7.0 to 7.0a, 7.0b and 7.1.
However I can't find any difference in the Generated library code(.c and .h) and binary(.hex).
What is the difference between version 7.0 and 7.1?
Are there any functional differences?
MPN CY8C4025LQI-S411
Naoaki Morimoto
Hi @NaMo_1534561 ,
For MPN CY8C4025LQI-S411, I created a project in PSoC Creator and the latest CapSense Component I could see was CapSense v7.0.
Please refer to component datasheet > Section Component Changes for more details.
Thanks!
Kind Regards
Arpit Srivastav
Hi Srivastav-san,
Thank you for reply.
You can see the CapSense Component v7.1 using update components in PSoC Creator 4.4.
The Component Changes section of the datasheet says "Version update for background changes".
What are background changes?
Naoaki Morimoto
Hi @NaMo_1534561 -San,
Really sorry for replying late to this query. As for the answer, please refer below:
There were build error for two MPNs (CY8C4746LQS-S263 CY8C4747LQS-S453) for the MagSense component. The generated file MagSense_SensingISX_LL.h contained errors.
In scope of this, the code generated by the MagSense component was changed to take into account specifics of two mentioned MPNs
Thanks!
Kind Regards
Arpit Srivastav
