Hi everyone! I'm using CapSense block V7.0 with PSoC Creator 4.2. Communicating via MiniProg4 (I2C-USB bridge). Problem is the connection to Tuner. I have managed to connect to Tuner, several times, but always with exactly the same .hex. Now, I have changed .hex, and now connect process fails, indicating checksum mismatch. I have downloaded the .hex via Debug->Program, and also with PSoc Programmer. Both processes have been success. But, when opening Tools->Component Tuners->connect, it fails. "Mismatch checksum for the data stored in the device and the data loaded into the Tuner (expected: 0xBD36, obtained: 0x8034)" which by the way neither is the checksum read from programmer! Any ideas?
CapSense
Hi Sobhit and thanks for the reply. Yes I checked those items you suggested. Like I said it was already working before changes so my problem was still existing. But, after deleting all generated output files from Debug and Release folders, connection was success after re-generating the code. I still dont know the root cause, but it's working now!!
Markku
Hi @TheSlider ,
Please consider these two points:
- The CapSense Tuner needs to be launched in the same project where it was created. If a .hex file of one project is being launched by the tuner of another project, it would crash. You should have only one project for generating .hex file and launching the Tuner.
- Does your code(in the .hex) contain CapSense Run Tuner API ? Check this one also.
Can you please try these out on your desk and let me know if you can interface it, or the problem still exists.
Sobhit
Markku
